Ticking sound -- NOT A SLIPPED SLEEVE
#131
That pickup tube is an embarrassment, I agree. I'm sure that's the pressure issue but when I put it back together I'll get the pressure readings. It was reading low at idle.
ANY tips on cleaning the pickup tube other than using a dental pick? I cleaned it last time by blasting brake cleaner from the other end.
#132
Thanks, Dro. I don't care so much about driving it as defeating it. My only hard deadlines come once a year for inspection and registration.
#133
I am hoping that is right! If so, very easy fix. And that would explain why the ticking transcended head changes and rocker changes, and still sounds like it is coming from the rocker area. I wish I was observant enough to remember whether the ticking occurred (while driving) after I stopped at a light or something. Anyway, I am going to clean the screen and put it back together.
#134
Almost got it done but the crank pulley is giving me trouble. Mine is a replacement pulley and it is TIGHT, so getting it lined up it really really difficult. Try again tomorrow. That's the last thing.
By the way I looked for a replacement pulley. Cheapest price for new I could find is 488 dollars. Wow! What the HECK?!
#135
#136
That's the plan (heat the pulley sleeve). I have to go get a new bottle of gas. But I'll have to beat the pulley off first. Too late and too loud for right now.
I'm going to be real careful with this pulley after seeing what a new one costs. Presumably there is no cure for the one that started pressing out the rubber. I do have one more but it is hiding somewhere in the garage.
#137
Found my third pulley. It is in great shape. I got the second one off (not easy. Messed up my engine paint!! Ugh) and the third one is tight too. I tried both of them on another engine and the slide right on, so I basically have a slightly larger crank end on this engine. Nice. Of course I do! I put the pulley in the oven and am awaiting it's expansion.
I decided against using a torch because I don't want to chance ruining the front seal.
#138
Can you do make some brownies or something on the shelf the pulley is not on?
#139
They are quite hot to hold, even with gloves.
I pulled one out and it immediately went halfway on, so there is something to it. I put it back in so it would bake all the way through. Now that I know how expensive pulleys are I googled and the can be rebuilt. Yay. I'm rich!
I turned the pickup tube over to my wife. She should get a job cleaning operating rooms because she never misses anything. The pickup tube looks new. Shining. Gleaming. I mean, even the tube itself which I didn't ask her to do. She made he front cover look new. I'm weighing the chances that she will agree to clean one part at a time until my entire collection (hundreds) look new.
Today is the day. I hope.
#140
Hahaha I am actually using both shelfs! I am baking both pulleys so I have options.
