Time to mod
Old Feb 17, 2012 | 04:58 PM
NolaRover504's Avatar
7th Gear
Default Time to mod
Hi ya'll,
So my engine has taken a small turn for the worse. It appears I have a bent rocker or sheered cam which is causing some bad knocking/pinging. So with it going in to be fixed I am going to take this opportunity to make some mods. Things I am thinking about getting done are new rotors/pads, 2" suspension lift, new wheels and tires. If you all could reccomend some quality companies and wheel tire combos that would be much appreciated. I use my vehicle quite often for outdoor adventures and need to make it more capable. It is basically stock now so any other ideas on mods would be great!
Old Feb 17, 2012 | 06:22 PM
Better hold on the mods until engine repairs are priced out..... what year? And consider changing the oil pump and water pump, if needed.
discoland
Sep 6, 2023 01:42 AM
ljdiscovery
May 15, 2008 09:26 AM
Skibum232
Nov 20, 2007 05:46 PM
larsenken
Sep 7, 2007 08:19 PM
