timing chain & gears @150000 ?
Old Aug 3, 2009 | 09:23 PM
XCELLER8's Avatar
Default timing chain & gears @150000 ?
After just finishing the head gasket job , I'll now turn my attention to the leaking front cover gasket, but I was wondering if you guys had any opinion on changing the timing chain and gears.....I intend to replace the front crank seal, water pump and fan clutch while i'm there, maybe even the oil pump gears, there's 150,000 miles on her and It seems to me that this wouldnt be money wasted to do the timing chain as well , any thoughts ?
98 DI
thanks
Old Aug 3, 2009 | 09:31 PM
you have it apart and the parts are cheap...but if it aint broke dont fix it...personally I would not do it but thats just me.
Old Aug 3, 2009 | 09:47 PM
98roverguy's Avatar
I'm not certain but the chain and gears are parts that do not readily wear out. If there's no problem with it I say leave it alone. It's really just up to you.
Old Aug 3, 2009 | 10:19 PM
roverguy7's Avatar
ive seen well over 250k miles with no notable wear, the chains always have what seems to be too much play in em, i wouldnt do it, but if you feel like spending money, why not
Old Aug 4, 2009 | 07:47 AM
Inspect and replace the chain and gears as necessary, replace the oil pump for sure, with your mileages it will be getting warn.
A5scott
Jul 11, 2015 07:25 PM
DISCOENO
May 4, 2014 03:08 AM
Martin Rodriguez
Feb 25, 2014 08:55 PM
MrFlea1
Jan 9, 2012 09:23 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
