Timing Gears
Old Jul 28, 2012 | 08:03 PM
LRScott's Avatar
Default Timing Gears
Well, I got the water pump off with the stubborn fan clutch still attached. Despite trying many techniques to hold it and take it off the usual way, failed. So, now for the fun stuff .
I am in the process of changing the oil pump out on my Discovery after it's oil light would remain on a bit longer than it should. Plus it does not sound near as smooth as my RR, and it falls within the particular (up that creek) vin range. I haven't gotten the timing cover off yet, but the sump is down and the water pump and fan clutch are off. The only thing about the project that I'm a tad fuzzy about is the timing chain and gears. The chain has slack in it so I ordered a new set from AB. Taking them off looks simple enough, but is there some locking/toque tool I need to buy/fabricate? I've looked in the rave manual and it looks really straight forward... Is it really THAT easy? I just did my Jag's timing system with the VVT units and dual over head cams. It required 3 locking tools! I'm not sure if the rover V8 is an interference engine, but I what to make sure I get the timing perfect.
As always, I appreciate any suggestions, thanks in advance!
Old Jul 28, 2012 | 09:07 PM
RoverMasterTech's Avatar
nope, zap the cam bolt off with a 3/8 gun, remove/install new chain/sprockets with squares facing down towards each other, loctite bolt and torque down.
Old Jul 28, 2012 | 09:27 PM
bosshogt's Avatar
Thats good to know. I will be looking diligently at my RAVE. This weekend I'm doing my oil pump gear and timing chain too. Not excited about this job but needs to be done before I move to Colorado and dont have a guaranteed place to work on the Rover.
I wonder If I will see a slight increase in gas mileage since there is less slack in a new timing chain. Just curious?
Old Jul 29, 2012 | 01:52 AM
LRScott's Avatar
Thanks for the input Chris! One question though, once I align the sprockets for removal and remove them, will the camshaft stay put or jump over to a different timing? The reason I ask, my Jag required two locking tools for all four cams, otherwise they would move to an incorrect position because of the valve springs/timing of the overly complex head ache DOHC V8. I realize the rover V8 only has one cam though...
Main question,
If I remove the sprockets after I aligned the timing gears, will they stay in position?
A5scott
Jul 11, 2015 07:25 PM
DISCOENO
May 4, 2014 03:08 AM
Martin Rodriguez
Feb 25, 2014 08:55 PM
MrFlea1
Jan 9, 2012 09:23 PM
XCELLER8
Aug 4, 2009 07:47 AM
