The pipe is held in the manifold by a flange that is bolted directly underneath where the pipe enters the manifold. The fitting is sealed with an O-ring that you'll likely want to replace with a new one. Lube the O-ring with engine oil or Vaseline before reinstalling the pipe. You can pick up one from the dealer, or I have an extra I can drop off to you.
