Tips on replacing downpipe to manifold gasket and bolts
Old Jan 27, 2012 | 10:18 PM
ShortTom's Avatar
Default Tips on replacing downpipe to manifold gasket and bolts
So several months ago I was attempting drop the exhaust to replace a crank sensor and ended up breaking one of the manifold to downpipe bolts (is that called the collector?). I forgot dropping the exhaust and got the job done then, but now I have a really annoying ticking.
Advice? Will I have to pull the entire manifold on that side? Has anyone had any luck drilling/tapping downpipe bolts while the manifold is still on the engine?
Old Jan 28, 2012 | 09:25 AM
Depends what is leaking and where. Spray all the nuts and bolts with PB Blaster or WD-40 the night before you want to remove and replace the bad gaskets and you should be fine.
Old Jan 29, 2012 | 09:48 AM
ShortTom's Avatar
Thanks Mike. Any feedback on how best to get the broken bolt out? Heard in another thread that it's nigh to impossible to drill/tap without taking the entire manifold off the truck...
HOPING that's not the case.
Old Jan 29, 2012 | 07:29 PM
Stocksuspension's Avatar
drill it out and run a bolt
Dogwood
May 3, 2015 09:53 PM
Shryan
Apr 1, 2013 08:53 PM
TripleThreat
Mar 12, 2013 03:23 PM
rrhyne
Mar 23, 2011 04:12 PM
