Tire Rotation
Just sent Disco Mike an update on the 3 amigos and how I got them to go out on my 2000 SD.
I started with three codes ( rough terrain code,intermittent L F sensor signal, L F sensor circuit).
Removed the sensor and cleaned it,checked it for ohmsand it measured 1015 ohms, which is correct . Checked the harness for continuity from the plug on the fender well to the SLABS pins, it was OK. Then I had the codes erased / ECU reset.
I have driven it over 300 miles and the lights remain off.
In regards to rotation, the right way is LF <-> LR and RF <-> RR.
Also, I run 39 PSI all around when I do interstate driving at 80 +.
