Tire Rotation
Old Jan 20, 2009 | 10:44 PM
  #21
unimoged's Avatar
Default RE: Tire Rotation
Just sent Disco Mike an update on the 3 amigos and how I got them to go out on my 2000 SD.
I started with three codes ( rough terrain code,intermittent L F sensor signal, L F sensor circuit).
Removed the sensor and cleaned it,checked it for ohmsand it measured 1015 ohms, which is correct . Checked the harness for continuity from the plug on the fender well to the SLABS pins, it was OK. Then I had the codes erased / ECU reset.
I have driven it over 300 miles and the lights remain off.
In regards to rotation, the right way is LF <-> LR and RF <-> RR.
Also, I run 39 PSI all around when I do interstate driving at 80 +.
Old Jan 20, 2009 | 10:54 PM
  #22
Jupiter Rover's Avatar
Do you have a uni mog? If so, PLEASE post pics of the sexy beast!
jrb
Dec 23, 2012 09:02 AM
pgk
May 19, 2012 08:44 AM
Willie00d2
Nov 14, 2010 07:11 PM
mishon
Feb 28, 2010 09:21 PM
mwsharb
Mar 12, 2009 07:52 PM
