Tire Size for 2003 D2
Old 02-25-2014, 09:07 PM
Harvey Swift's Avatar
8th Gear
Originally Posted by ZGPhoto
Not really if you keep the sways and don't do a light duty spring setup.
I think I will go medium spring and have 2" list. I can always go more later on. I did look at heavy duty springs but I wont be adding enough weight to compensate for the extra pressure.
2" Terrafirma it is. Do the Shocks come with new bolts or do I need to get them separately?
Old 02-26-2014, 12:21 AM
Rover_Hokie's Avatar
Consider the TF +2 shocks. That way you can disconnect the sway bars at some point when off-road or add sway bar disconnects and get more articulation. I have those with MD lift and they work well. I have recently purchased sway bar disconnects for all 4 corners, but have not installed them yet, so will have to see if I get what I was expecting. I have also added the extended SS brake lines that can come in handy with the 2" lift and definitely useful with the sway bars disconnected, and you can now get more down travel where the extended brake lines are needed.
Old 02-27-2014, 07:17 PM
8th Gear
I have been looking at the purchase of the lift kit and was debating heavy duty shock turrets, although I can't track down HD securing rings for D2. I can find D1's are these compatible or does the D2 not require these?
Old 02-27-2014, 08:13 PM
jafir's Avatar
People use d2 rings on d1, because they are better, so I don't see why you couldn't go the other way.
Old 02-27-2014, 08:40 PM
8th Gear
Thanks, as an update I have now purchased a terrafirma 2" lift kit on Medium springs. Hurry up FedEx!!
DiscoRover007
12-15-2010 04:54 AM
jigray3
10-14-2010 06:54 PM
jigray3
10-09-2010 09:27 AM
samsly
Tires
02-27-2006 07:01 AM
jhstew1
06-14-2005 03:41 PM
Quick Reply: Tire Size for 2003 D2
