Tire size
Old Apr 2, 2013 | 02:08 PM
robersonb's Avatar
Default Tire size
One can't use 255-70-18's without a lift can you? Found a set with good tread left with an almost new spare for $150.
Old Apr 2, 2013 | 02:19 PM
ZGPhoto's Avatar
Well... that all depends you see...
Old Apr 2, 2013 | 02:50 PM
kfx4001442's Avatar
255-55-18 is the stock. I bought a full set of Nexxen Roadians 255-60-18(GREAT tires by the way) and I never noticed them rubbing. However durring my last oil change I noticed a small hole(dime sized) worn in the center of the plastic wheel well liner. I assume they just barely rub when turned all the way left or right. I bet they would work but the holes worn in your front plastic wheel well liners are gonna be little bigger than mine, but who cares. I'd try it. I noticed a significant better ride when going to the 255-60-18. I bet the 70 would be even better. They will only be 10%(of 255 millimeters) taller than my Nexxons. The width remains stock at 255 millimeters.
Old Apr 2, 2013 | 03:25 PM
mtrionfo's Avatar
I'm not so sure they would fit without a lift.
Going from 255/55 to 255/60 increases diameter by an inch, from 29 to 30, while 255/55 to 255/70 is a 3 inch increase to 32 inch diameter tire. That might be a little too much on original springs.
Really handy tire calculator I have used for years: Tire size calculator
Good luck.
Old Apr 2, 2013 | 05:13 PM
bballjames's Avatar
Good luck.
That is a cool website. I like how it even gives you an approximation of what your speedometer change would be.
Old Apr 2, 2013 | 05:24 PM
ZGPhoto's Avatar
That site isn't bad, but for a much more in depth description including gearing, checkout this one - Tire Size Calculator - Compare Tire Sizes
Old Apr 2, 2013 | 08:17 PM
taylor15's Avatar
the tacoma world calculator is the one I've always used as well. Great resource
Old Apr 2, 2013 | 08:34 PM
robersonb's Avatar
Thanks guys. And ZG, I happen to have one of those tools Just never thought about using it on my Rover yet lol.
Old Apr 3, 2013 | 09:26 AM
ZGPhoto's Avatar
Just wait it'll happen, it always does!
Old Apr 3, 2013 | 10:17 AM
jafir's Avatar
The calculator at ashcroft has presets for the land rover parts, so that you don't have to look up the standard ratios. It doesn't do tires... you just tell it the tire size.
Ashcroft Transmissions - Ratio Calculator
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
samsly
Tires
Feb 27, 2006 07:01 AM
chefman
Jan 18, 2006 10:15 AM
jhstew1
Jun 14, 2005 03:41 PM
