Tire size conflict?
Old Nov 13, 2014 | 06:31 PM
  #21
cobbcj7's Avatar
Would the 265/75/16 fit on the Disco 2for week or so till I get the 2" lift installed? Strictly road driving
Old Nov 13, 2014 | 07:26 PM
  #22
G150driver's Avatar
I'm running 235/85r16's which have about the same diameter. I had no problems in the week or so I was driving around without the lift. Not sure if the additional width of your tires would be a problem though.
Old Nov 13, 2014 | 07:38 PM
  #23
OilPatch's Avatar
18" or 16" rims?
Sadly my disco project has the 18s. I would love 16s but I don't want to spend the money to make the swap with all the other stuff I'm buying.
Old Nov 13, 2014 | 08:50 PM
  #24
Alex_M's Avatar
If you're doing much off roading, it's worth the difference to atleast buy a set of 16" steelies. If it's simply not in the budget then I understand, but if I were in your shoes I would try to stretch it if at all possible.
Old Nov 13, 2014 | 09:57 PM
  #25
OilPatch's Avatar
I'd prefer not to go steelies, because I hate how they look. I came across some for 220 shipped, is that an okay price for used OEM 16"? I personally hate this popular look of big rims on off road cars. So if had hadn't already dropped a lot on a new engine, and a lift, and pads and rotors, and all sorts of other odds and ends, then I would be doing this no problem.
I wont do hard core off-roading in this (rock crawling), but I would like it to get me anywhere I wanna go. I have a ford raptor that I take out when I need to scratch my off road itch.
Old Nov 19, 2014 | 07:10 PM
  #26
tberg44's Avatar
Anybody have a good recommendation for the largest tire size one could put on the stock 18in rims without lifting the thing? Thanks!
Old Nov 20, 2014 | 12:26 AM
  #27
Dave03S's Avatar
How much room do you have? Have you measured the distance from the center of the hub to the wheel arch?
This will tell you if your stock suspension is sagging or not, which will tell you how much tire you can get without fixing your suspension, which will continue to sag more and more at your mileage.
Old Nov 20, 2014 | 09:02 AM
  #28
tberg44's Avatar
About how much space should I have on a stock setup? (roughly) I'll run out and measure as soon as I can get out of the office.
Old Nov 20, 2014 | 10:11 AM
  #29
Dave03S's Avatar
There is an active thread on that right now!
https://landroverforums.com/forum/di...rements-56226/
Old Nov 20, 2014 | 12:21 PM
  #30
drowssap's Avatar
i think the rave says 19 or so for stock
