Tire size conflict?
I'm running 235/85r16's which have about the same diameter. I had no problems in the week or so I was driving around without the lift. Not sure if the additional width of your tires would be a problem though.
If you're doing much off roading, it's worth the difference to atleast buy a set of 16" steelies. If it's simply not in the budget then I understand, but if I were in your shoes I would try to stretch it if at all possible.
I wont do hard core off-roading in this (rock crawling), but I would like it to get me anywhere I wanna go. I have a ford raptor that I take out when I need to scratch my off road itch.
Thanks!
How much room do you have? Have you measured the distance from the center of the hub to the wheel arch?
This will tell you if your stock suspension is sagging or not, which will tell you how much tire you can get without fixing your suspension, which will continue to sag more and more at your mileage.
