Tired Old Fender Flares
Old Jul 13, 2012 | 03:37 PM
javven's Avatar
Default Tired Old Fender Flares
If you've a little patience and a lot of masking tape... you can spruce up your fender flares pretty easily.
I took one look and figured out removing and re-installing them was a no-go. If you do remove yours you'll have it even easier.
I used Rust-O-Leum (sp?-not by the can right now) truck bedliner. It's not rubbery after application and has quite a nice texture. It's very similar to the mirrors' visually though it feels a bit more coarse. The only real info here I guess is the texture - it was 'just right' for this job. I'm seriously considering doing my grille in it before I put it back on. My LR's white so I think the contrast would look fine.
I masked off then sanded the flares down with 80 grit to remove the worst of the roughness from them. A couple coats per the can's directions and voila. I'll post some pictures when I can.
Old Jul 13, 2012 | 03:41 PM
Bkreutz's Avatar
Someone beat you to this. There's a section at the top of this forum titled "Write ups, How To's and Must read's"
https://landroverforums.com/forum/di...y-32736/page5/
Old Jul 13, 2012 | 03:56 PM
javven's Avatar
heh - so it would seem.
I still like my four-ingredient method. Water (cleaning the dust up). Sandpaper. Masking tape. Bedliner stuff. Maybe throw a rag in there or two was about it... You can over-think this but there's no reason to.
YMMV...
mb8780
Nov 15, 2012 07:12 PM
Kraftyz51
Aug 13, 2007 10:56 AM
mb8780
Mar 21, 2007 08:18 PM
joelxa513
Nov 10, 2006 12:33 PM
edthediscoman
Oct 28, 2005 05:10 PM
