tires
Old Apr 20, 2007 | 12:08 AM
97nwdisco's Avatar
Default tires
Hi again, I about ready to bay some new tires. I have looked on a few web sites and they all say it came with 255x 16. I checked and my disco has 235x16. is there any good reason to go to a narrower tire other than following the rain groves better.
Old Apr 20, 2007 | 10:40 AM
Default RE: tires
What will you be using your truck for, do you go off road at all, do you want a little better ride, if so you may want to consider going to a completely different tire size like the 245/75/16. Slightly taller, more side wall for a better ride and they will last longer.
By the way, what year is your Disco?
Mike
Old Apr 21, 2007 | 01:08 AM
llesra's Avatar
Default RE: tires
if you have a d1, stock tire size is 235/70/16. if a d2, 255/65/16.
Old Apr 22, 2007 | 10:26 PM
97nwdisco's Avatar
Default RE: tires
It's a 97 dico. it's life is mostly over the road. (sadly) not enough time to play.
Old Apr 23, 2007 | 12:03 AM
Default RE: tires
I still like the 245/75/16's be it on or off road. Large then factory tire, it gives a better ride, appearance and usually will last a little longer.
Mike
Alex_M
Nov 22, 2018 12:53 AM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
bikingteacher
Sep 16, 2010 06:44 PM
RoverDude71
Mar 2, 2009 11:03 AM
