Top end assembly questions
Old Feb 17, 2020 | 04:19 PM
Friday Night Disco's Avatar
Get a wobble or swivel
Old Feb 17, 2020 | 05:57 PM
Sixpack577's Avatar
Same problem as above, brand and small differences in size can make a difference if they have clearance to fit at the firewall.
Some fit, some don't, and I tried alot.
Old Feb 17, 2020 | 06:07 PM
i used this 1/2 wobble and the electronic 1/2 torque from Harbor Freight
Old Feb 17, 2020 | 06:23 PM
Sixpack577's Avatar
Yeah, some work, some don't.
Overall height and wall thickness differences.
I used this 1/2" drive Mac socket with built on swivel(Mac, my only sockers and tools that rust, wth)
The 3/8" drive Matco is taller(and not really strong enough)
The Craftsman is much bulkier, and doesn't fit.
My friend's toolbox is in my garage too, so I tried several other socket and swivel combo's too.
I'm not arguing what's best, only that not everything will fit in that tight spot at the firewall.
Old Feb 19, 2020 | 11:29 AM
ahab's Avatar
Personally I'd be reluctant to use a swivel on a headbolt due to the changes in torque value that the swivel will impart. Any other bolt I wouldn't be *too* concerned about however given the high number of HG problems these engines are already prone to, this seems a bit risky. Regarding the fuel rail, my preferred method is to remove the fuel pump relay or fuse and crank for a bit to build oil pressure throughout the journals before the engine fires, especially with hydraulic lifters. If you have a gauge you can see pressure build (something is better than nothing) and then bring the fuel pump back online.
Old Feb 19, 2020 | 11:39 AM
Sixpack577's Avatar
I agree that a swivel could slightly change a torque value, but if you torque the head bolts with the engine in the truck, you Need a swivel to get to the lower rear head bolt on each side.
Old Feb 19, 2020 | 12:43 PM
Richard Gallant's Avatar
@Sixpack577 and @ahab thanks for chiming in no way a swivel will work on mine, a small 80 ft pds torque wrench has a small enough head to get in there, I checked ratchet heads to figure it out the size I need.
I managed the 20 with a swivel barely.but I do not have confidence even it that.
The nice thing about studs and bolts iti s a torque setting and not an angle.
@ahab good suggestion and I have an oil pressure gauge going in
Old Feb 19, 2020 | 01:07 PM
Sixpack577's Avatar
In hindsight, nothing 1/2" drive myself or my friend had would fit without a swivel for removal(while in the truck)
And last time and this time coming, putting heads on will be out of the truck.
I do have several torque wrenches, and my 3/8 drive may fit on the rear lower head bolts to torque it, without a swivel.
I'll check for curiosity once it's back in.
I think it still comes down to brand/shape/style, as to if your ratchet or torque wrench and standard socket will fit in there or not.
Old Feb 19, 2020 | 01:18 PM
@Sixpack577 I will post an image and measurement of what end up using
worsethenu
Nov 9, 2012 10:47 PM
Rearden Steel
Dec 22, 2010 05:38 PM
audiS4S6
Apr 22, 2010 08:51 PM
Gordon Bombay
Dec 15, 2009 11:03 PM
Tamango
May 16, 2008 06:20 PM
