Top end engine rebuild w/ pics and video
Old Mar 10, 2015 | 11:35 AM
  #41
drowssap's Avatar
Someone makes one with needle bearing insteed of ball bearings, BRS or some german company bit i never found them again
Old Mar 10, 2015 | 11:50 AM
  #42
dusty1's Avatar
Originally Posted by 2003DiscoAZ
Thanks guys, is the inline thermostat mod worth the effort? I hear nothing but good things thus far from the thread I have been reading.
https://landroverforums.com/forum/di...rmostat-67535/
easily one of the best modifications that i made to the cooling system.i have since moved away from it, but it made the temps more stable than what i was getting in the original bypass set up.
for about the same price of a td5 stat, you can get a nice housing and stats
Old Jul 15, 2015 | 02:07 PM
  #43
2003DiscoAZ's Avatar
Hey guys, it's been a while, and nearing Monsoon Season here in Tucson so I have started working on the truck again! I have an issue here, broken hose, and not sure what it is (photos below, the hose with the silver tape on it)
http://i241.photobucket.com/albums/ff58/oatesfamilyablum/WIN_20150715_120113_zpsixyya8el.jpg
http://i241.photobucket.com/albums/f...ps7njkiviy.jpg
Old Jul 15, 2015 | 02:36 PM
  #44
abran's Avatar
Secondary air hose. Its for the emissions control.
Old Jul 15, 2015 | 02:44 PM
  #45
So this hose should connect to the SAI ?
http://www.roverparts.com/images/2ndaryAirInjEngine.jpg
Old Jul 15, 2015 | 03:34 PM
  #46
abran's Avatar
The hose I thought you were referencing was the corrugated one. The hose you are showing now is the small non corrugated, correct?
I'm not positive but I think that small hose is connected to a filter/dryer element associated with SAI. But I'm not sure. Let's see what the experts say.
Old Jul 15, 2015 | 04:08 PM
  #47
coors's Avatar
Looks like it's connected to the vacuum canister. Does it connect to the Manifold?
Old Nov 20, 2015 | 10:56 PM
  #48
Long time since I have chimed in here, but I have just finished putting the engine back together and doing the first start. Started up just fine, but then 5 mins after running I noticed a small amount of smoke coming from the engine. I'm not sure where it is coming from, but there appears to be a coolant leak somewhere, at least I am hoping that it is not the head gasket that I just replaced! Any suggestions on things to check?
Video coming soon!
Old Nov 21, 2015 | 07:07 AM
  #49
coors's Avatar
Could it be PB blaster, sea foam deep creep, etc burning off? Grease burning off the manifolds / exhaust pipes?? Don't know I'm not there
Old Nov 21, 2015 | 12:26 PM
  #50
Smells a lot like sweet green radiator fluid. Also there is fluid flying out the exhaust pipe. I'm going to shoot a video now to give more context
