torque head bolts (cold)
Old Jan 21, 2009 | 06:52 AM
mcrw's Avatar
Default torque head bolts (cold)
After dumping copious amounts of oil and then coolant last week I'm replacing the head gaskets.
I'm about half way through tearing it down. Looks like the valley pan gasket was the culprit for the oil, it's gone at both front and back.
When I get the heads off and back from the machine shop I have a question about torquing them down.
It pretty cold here (14 degrees), the garage is pretty cold and after heating for a while I can get it to about 32 degrees.
So when it comes to torquing the heads down will the temperature be an issue?
I can work in the cold but don't want to screw up the heads and be doing this again in a few months.
Will a freezing block be an issue?
Thanks,
Mark
Old Jan 21, 2009 | 07:17 AM
Default RE: torque head bolts (cold)
Good question, I don't have an answer but look forward to the feed back.
Just a question, you are using new head bolts, right?
Old Jan 21, 2009 | 08:19 AM
mcrw's Avatar
Yup, new head bolts.
I'm hoping the temp of the block won't make a difference. If it does I suppose I'll be renting a construction heater to get everything toasty :-)
Old Jan 21, 2009 | 03:08 PM
jkid's Avatar
I did mine in November with no heat and it was probably in the 30's in the garage. I've had no problems so far after a few thousand miles, so above freezing at leastit seems like you should be good.
cozman
May 31, 2015 06:39 PM
boo_who66
Apr 25, 2014 08:57 AM
me 2
Mar 18, 2013 07:17 AM
Discolife
Jun 14, 2012 02:16 PM
arives350
Aug 13, 2009 05:02 AM
