Torque spec needed-RAVE not listing
Old Oct 6, 2011 | 08:22 PM
boris_gti's Avatar
Default Torque spec needed-RAVE not listing
Does anyone have a correct torque spec on the oil pump cover? Phillips bolts on the inside of the timing chain cover. See picture bellow.
Or do I just go a good old "hand tight"?
Thanks!
Attached Thumbnails Torque spec needed-RAVE not listing-landy-timing-cover-008.jpg
Old Oct 6, 2011 | 08:46 PM
In the overhaul manual section, found this for 4.0 and 4.6 engines; under torque wrench settings:
Oil pump cover plate screws ** . . . . . . . . . . . . . . . . . 4 Nm 3 lbf.ft
Oil pump cover plate bolt ** . . . . . . . . . . . . . . . . . . . . 8 Nm 6 lbf.ft
Spark plugs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nm 15 lbf.ft
** Coat threads with sealant, Part number STC
50552 prior to assembly.
Note: they list every other torque it down setting for places you didn't even know they had bolts...
Old Oct 6, 2011 | 09:48 PM
boris_gti's Avatar
Thanks Buzz,
I needs to get to know the RAVE a little better I guess.
It looks like "Part number STC 50552" is Loctite (blue).
Thanks again!
Old Oct 6, 2011 | 11:10 PM
The RAVE, (Rovers A'int Very Economical) is like an onion, many layers. I think the workshop manual is geared toward quick fix parts changers, and the overhaul toward the master guys (and gals!) that would be entrusted with something more complex than swapping an alternator. Most dealers want lots of the quick fix, and so do the techs.
chicane
Oct 24, 2014 01:03 PM
utah95
Feb 20, 2014 11:33 PM
wastedincome
Oct 24, 2012 03:10 PM
grandkodiak
Mar 29, 2011 03:04 PM
snorlax
Apr 7, 2008 02:16 PM
