2003 Disco Traction Control?
Old Jan 25, 2009 | 03:06 PM
daniep's Avatar
Default 2003 Disco Traction Control?
Hi does anybody know if it is possible to turn off the traction control on a 2003 discovery it kinda makes me mad when I can't have fun on the snow. thanks
Old Jan 25, 2009 | 03:10 PM
unimoged's Avatar
Default RE: 2003 Disco Traction Control?
I do not believe that you can disable traction control on Disco II.
Old Jan 25, 2009 | 03:14 PM
daniep's Avatar
ok thanks
Old Jan 25, 2009 | 04:58 PM
Urban Panzer's Avatar
You can if you have a CDL in the transfer case, but because you have a 2003, then you wont have that either....
You "could" simply pull the fuse for the ABS / TC. that would stop it. Fuse 28 (10A)labelled ABS in the pasenger compartment fusebox. You must pull the fuse with the ignition OFF, and note it "may" record a fault.
Old Jan 26, 2009 | 01:58 PM
Why do you think you can't have fun in the snow with the ETC on???
Be reall careful when, "Having fun in the snow" cause you can blow out your spider gears very easily.
michaelfisk
Apr 28, 2018 04:22 PM
gamecockdisco
Jul 12, 2010 08:34 AM
johnkbl
Dec 8, 2009 07:13 PM
rodrick smith
Apr 13, 2007 06:09 PM
