Traction Control Light and Rattle Noise
That noise is the ABS modulator motor engaging the shuttle valves which rapidly apply pulsing micro bursts of brake fluid to whichever wheel speed is greater determined by the ABS wheel speed sensors. This action works with the differentials on the truck to drive power to the wheel(s) that have traction and not to the wheels that don't. This is accentuated through rough corners as you discribe.
You can rest assured that when this happens, the traction control is doing what it was designed to do.
Check the ABS sensor on the offending wheel. I had the same issue and it was a failing hub. Gears ground up so much it caused a build up on the sensor and ground it down. See here: https://landroverforums.com/forum/di...-w-pics-59222/
I've generally noticed traction control by a really rapid ticking sound(and the green dash light) from what sounds like below and to the left of the steering column. I've always assumed it was a relay or some such.
All in all, it's pretty surprising how much traction I get before I hear it kick in. Other vehicles(both front and rear wheel limited slip) have spun where the rover doesn't even blink.
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
