Traction Control Light and Rattle Noise
Old Mar 21, 2014 | 12:10 PM
kwarren76's Avatar
Default Traction Control Light and Rattle Noise
Each time I go over a bump while turning my traction control light comes on and I hear kind of a grinding / rattle noise coming from the left side of the vehicle.
I'm thinking it might be the ACE system? Any ideas? Thanks.
Old Mar 21, 2014 | 12:35 PM
dusty1's Avatar
is hub in good order?
Old Mar 21, 2014 | 12:39 PM
DiscoJ's Avatar
That noise is the ABS modulator motor engaging the shuttle valves which rapidly apply pulsing micro bursts of brake fluid to whichever wheel speed is greater determined by the ABS wheel speed sensors. This action works with the differentials on the truck to drive power to the wheel(s) that have traction and not to the wheels that don't. This is accentuated through rough corners as you discribe.
You can rest assured that when this happens, the traction control is doing what it was designed to do.
Old Mar 21, 2014 | 07:10 PM
kwarren76's Avatar
Default Thanks
DiscoJ: Thanks for the explanation. I think I will likely not worry about it then.
Dusty: I'm not sure about the HUB. Maybe I will ask GBR to check it out next time I am in there.
Thanks again to both for the responses.
Kevin
Old Mar 21, 2014 | 10:00 PM
Dane!'s Avatar
My traction control kicks in every time I leave my neighborhood, there's a slick piece of road that I always goose it on and kind've drift the rover... but then the traction control kicks in and ruins my fun
Old Mar 21, 2014 | 10:18 PM
ralphobell's Avatar
Check the ABS sensor on the offending wheel. I had the same issue and it was a failing hub. Gears ground up so much it caused a build up on the sensor and ground it down. See here: https://landroverforums.com/forum/di...-w-pics-59222/
Old Mar 21, 2014 | 10:44 PM
dusty1's Avatar
Yeah... My point, too. Grinding/rattle is not the sound I expect from t/c. I have to work harder than a little bump in a turn to need it. (Slick spot or dolomite air born speed) .........the latter is fun, though.
Old Mar 21, 2014 | 11:10 PM
Dane!'s Avatar
Jack all the wheels up (one at a time) and feel for play in each wheel. Pull the top the wheel and push the bottom at the same time and feel for some play, that's a sure sign of a bad wheel (hub) bearing.
Old Mar 22, 2014 | 02:40 AM
jwigum's Avatar
I've generally noticed traction control by a really rapid ticking sound(and the green dash light) from what sounds like below and to the left of the steering column. I've always assumed it was a relay or some such.
All in all, it's pretty surprising how much traction I get before I hear it kick in. Other vehicles(both front and rear wheel limited slip) have spun where the rover doesn't even blink.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
NickMcAFP
Jul 24, 2010 06:52 PM
gamecockdisco
Jul 12, 2010 08:34 AM
troubled
May 21, 2008 12:51 PM
rodrick smith
Apr 13, 2007 06:09 PM
