Trailer Direction Indicator turns on when turning left
Old Jul 15, 2020 | 08:59 PM
203disco2's Avatar
6th Gear
Default Trailer Direction Indicator turns on when turning left
Hi guys,
I recently purchased a 2004 Disco 2. When I activate my left blinker, the trailer direction indicator light turns on and all the lights on my radio, AC, blink at the speed of the blinker. Both rear tail lights activate as if I put my hazards on. When my lights are on and I activate my left blinker, everything works fine. right blinker is no problem.
There is no trailer hitch on my car, but behind my rear left bumper light it looks like there may be wiring.
Any tips?
Old Jul 16, 2020 | 12:17 AM
Art H's Avatar
if you have the plug, then removing it is silly easy. Everything is behind the right hand taillight. If you pull it, you will find a small box stuck to the sheetmetal with double sided foam tape. Pull it out carefully and look at the wiring. There will be two plugs on it where it connects to the wiring harness of the truck, Unplug them and push the connectors from the Disco's wiring harness together to put everything back to stock.
Old Jul 17, 2020 | 02:29 AM
The Deputy's Avatar
Agree with Art. Remove the trailer module mounted below right rear tail light. It is probably corroded inside and is back feeding to find a different ground through the tail light circuitry. Once you turn the head lights on, it has to use normal ground route...that's why it works fine with head lights on.
Old Jul 17, 2020 | 06:52 PM
Frank4's Avatar
I wouldn’t start there at all.
Go to the parts store and get whatever the proper turn signal bulbs are. I bet $100 one or more are the wrong wattage. If you have even one that’s not the right size the computer thinks the extra power is going to a nonexistent trailer and sets off the light in the dash. If I wrong I’ll send you the money for the bulbs.
Old Jul 18, 2020 | 02:25 PM
XRAD's Avatar
Originally Posted by 203disco2
Hi guys,
that's a cool effect! sounds like a short, and someone's getting free bulbs.....
Old Jul 19, 2020 | 06:07 AM
SundayFunday's Avatar
Trailer plug wiring behind left rail light.
ive had same experience.
Livingintheskies
Apr 9, 2018 11:17 PM
NickAdams
Jun 3, 2013 04:13 PM
LandyFan
Nov 25, 2008 10:24 AM
usherjs
Sep 15, 2008 04:19 PM
mastercraft
Jul 17, 2008 09:35 PM
