Trailer and Harness Questions
Searched the forum and owners manual and wanted to make sure I'm correct on this.
The standard trailer hitch for the DII 2003 is a class III. Is this correct?
With a class III hitch my tongue weight it 500 pounds?
I'm trying to determine whether or not I'll be able to run this type of motorcycle hauler with my Disco
MTX Sport Motorcycle Carrier
Second set of questions is. I'm in Europe and every trailer here is the 7 pin round variety. I have the 4 pin flat harness and was wondering if there was an easy adapter (plug and play) or will I just be getting a universal harness and have to cut and splice.
Thanks in advance.
Thanks in advance.
You shouldn't need to wire lights to the bike carrier, your tail lights should be high enough to be seen over the bike.
Otherwise depending on the wire harness that was used, if it is a plug-n-play type, since you are in Europe, you can buy another plug-n-play wire harness with the correct European plug and just swap it out for the one you have now and save the flat four for later.
theswede
10-29-2015 01:05 AM
twilightcall
03-06-2012 03:11 PM
