trailer lights
Old Jul 17, 2008 | 07:54 PM
mastercraft's Avatar
6th Gear
Default RE: trailer lights
I have power before the black box because all of the lights work except for the left turn signal
and by the way what is the black box called??? sorry I am a new LR owner....
Old Jul 17, 2008 | 08:25 PM
Ok, why doesnt the left turn signal work? Is the bulb burnt out? That might be why your trailer lights dont work, so fix the left turn on the trk first, the black box should work then.
And I do not know what that black box is called, lighting adaptor maybe?
Old Jul 17, 2008 | 09:28 PM
6th Gear
Spike 555 the truck turn signals work fine and the "flasher units" as well
the only thing that doesnt work is the trailer left turn and I did check the trailer bulb
and switched with the other side and works fine I even made a test light and at the 7 pin
plug all work except for the left turn I'm gonna bet then its the box Ill have to check into finding one
Thanks
Old Jul 17, 2008 | 09:35 PM
Ok, I miss understood you, I thought that you said that the turn on the trk wasnt working either.
www.atlanticbritish.com for all your Rover parts needs.
gruehle
Jul 27, 2020 09:10 AM
rmgoutfitters
May 7, 2015 11:07 AM
USMC_Denver
May 8, 2009 12:41 PM
sanfranca
Sep 22, 2007 01:37 AM
