trailer wiring for disco II does not match trailer connector
Old Jul 27, 2020 | 09:10 AM
tres_amigos's Avatar
Default 4way flat to 7way trailer plug
Originally Posted by seaosrover
I just recently wired my disco for my trailer. You can get an adapter to take your 7 way round pin to a 4 way flat. Then get the 7 way flat pin recepticle to mount on your bumper that also has a plug in the back for a four way flat. Plug in the 4 way flat and you will have all of your lighting taken care of. You will then have to wire the brake control yourself. About 8 to 10 inches from your battery mount a 30 amp breaker to the firewall. Run a small length of 10 guage wire to the breaker then run a length of 10 guage wire from the other side of the breaker and another to the ground on your battery. Run both of these to your brake controller in the cab. There is a wire from the brake controller that needs to be connected to the wire on your brake pedal switch. The switch is very easy to take off its mount. One half turn and it will disengage and you will be able to pull it down low enough to get to the two wires on the switch. Use a circuit tester to find the wire that is hot when the switch is in the out position. If you have the tester on the wire you can than work the switch and when the switch is pushed in it will not have any current present. Connect to that wire. Than run a 10 guage wire from the blue brake wire from your controller back out of the firewall and back to the blue wire on your 7 way connector on your bumper. You now have brakes. You can have this done at an RV dealer but it really is pretty easy to do yourself. If you can find an adapter to go from the 7 way round to 7way flat you still will have to wire the brake controller. Happy Camping!!!! I will check back on this post to see if you have any questions or just send me a PM
The above is accurate and the way to go. I went exactly this route after researching Disco2 seven way trailer wiring not having first seen this post. Step1 = the native LR European wiring plug in the right tail light must be converted to a USA "4way flat" (I used the Atlantic British solution). Step2 = you run the remaining wires yourself (brake, power, reverse, ground). A good kit along with your brake controller manual such as the Tekonsha P3 will tell you everything you need to know. Not difficult, go slow and be careful deliberate connecting everything. I soldered/shrinkwrapped where ever I could -- the kit has butt connectors. eTrailer.com is remarkable. They have very clear, well-thought out solutions and online resources: They have a 'ETB7' kit for $100+ that has everything you need including the proper fuses (know that they're not your usual blade type fuses, instead, they mount in the engine bay and feature an auto-reset function should there be short etc. Given the criticality of the application (3000+ lbs attached to the back of your rover), you need/want this fail safe should there be a fault.
Enjoy
ab1200max
Jul 13, 2020 03:03 PM
evansjoem
Feb 16, 2014 06:49 AM
Snafu / Disco Fries
Jul 11, 2013 10:11 AM
mark d
Apr 11, 2013 01:03 PM
909felix
Feb 2, 2010 05:06 AM
