Trailhead chevy ls engine swap
Old Nov 2, 2017 | 07:07 PM
  #51
KingKoopa's Avatar
Why stop at the engine trans and TC? Put the axles under there to upgraded brakes stronger internals, axle ratios galore and parts at every AutoZone in the land.
Motor punches out with no effort 310 hp and 425 ft lbs of torque. A bit of massaging brings it to 400 hp and well over 500 ft lbs in case you bored.
Plus V10 Defender 110 hard to beat that level of cool
Agreed 9.75 rear end is a hoss. Idk though the long nose rover diff isn't that bad is it? I mean if I was doing a full drive train swap and upgrading axles to handle 37 + tires I think I'd just dive right into a tube chassis. At some point you have to draw a line right? Lol
Old Nov 2, 2017 | 07:36 PM
  #52
I think swapping the axles at that point wouldn't be that much harder and you are going to solve the drive shaft offset angle issues.
Old Nov 2, 2017 | 07:45 PM
  #53
KingKoopa's Avatar
Would you go with ifs? There are some pretty wicked 8.8 or 9" medium/long arm setups out there. 110 wheelbase would lend itself well to a "pre runner" oriented suspension. Although I wouldnt want to go full on Baja, just make rough track funner at 50-60mph.
Old Nov 2, 2017 | 07:51 PM
  #54
Awhile ago I would have said no to IFS. Now after spending a lot of time with the LR3's I would really consider it.
In the end I doubt the v10 would make it under the hood but it is a fun idea that makes me want to go to a Junk Yard and measure.....
dynomite
Mar 13, 2016 05:42 PM
joshjellel
Mar 6, 2015 09:18 AM
pimnmike
Feb 14, 2011 02:54 AM
rrgbemail
Dec 4, 2010 02:07 PM
DuplinDisco
Apr 26, 2008 03:14 PM
