tranny
Old Jan 1, 2008 | 12:17 PM
newdr's Avatar
Default tranny
MY LOCAL NON DEALER MECHANIC FOUND AN ERROR CODE IMPLING A PROBLEM WITH 4 TH GEAR MESHING. I CAN NOT FEEL A PROBLEM. WE PLAN TO HAVE A TRANY EXPERT TAKE A LOOK.
THOUGHTS?
Old Jan 1, 2008 | 02:09 PM
raid13's Avatar
Default RE: tranny
it's the mass air flow meter.
sometimes the air filter is not installed properly and the tab on the air
box bends over resulting in unfiltered air bypassing
filter damaging air flow meter. after replacement of
filter and air mass air flow meter you MUST reset engine and
transmission adaptions. better than a transmission :-)
Old Jan 1, 2008 | 03:49 PM
Default RE: tranny
What you have is a 733 or 734 fault code, not for a meshing issue, it indicates eith 3rd. or 4th. gear are out of ratio and as already mentioned, most likely it is a Failing MAF sensor, $130 on line, change your air filter and get the codes cleared. If you have any questions, get back to me.
Old Jan 1, 2008 | 05:34 PM
newdr's Avatar
Default RE: tranny
THANKS,
I TOOK THE AIR FILTER OUT AND CORECTED THE PINCHED CORNER,
THE CHECK ENGINE LIGHT WENT OUT
Old Jan 2, 2008 | 07:57 AM
Default RE: tranny
You have already saved some money this year, you are already in the plus catagory on your Rover account.
LiftedRover96
Feb 11, 2006 01:46 PM
r1dad
Nov 12, 2005 12:19 AM
Bene
Oct 27, 2005 03:30 PM
Bene
Oct 26, 2005 11:17 PM
Bene
Jul 10, 2005 09:42 PM
