tranny in Park, tapping noise when brake applied
Got in my 2001 DII tonight, started it, and pressed the brake pedal down and heard and felt a clunk from below the shift stick - never heard/felt this before - seems to be doing it every time I'm in park and press the brake now - assume it has to do with the shift lock...? Advice? Will this worsen? What can I check? Do? Thanks!
ok, so my D2 is running and I'm parked, I tap the brake to put it in Reverse, and I hear a noise in two places simultaneously. in the left side by the turn signals, I hear what sounds similar to the turn signal noise... and at the same time I hear and feel a light tapping sound from under the shifter... like something is poking up from under the shifter.
only happens when it's running, in Park, but not when moving
no idiot lights are lit on the dash... but the ultra gauge is showing pending code 1668. maybe unrelated
any ideas?
thanks
scott
any ideas?
thanks
scott
Green Manual Disco
09-07-2012 02:18 PM
