tranny in Park, tapping noise when brake applied
Old Jul 2, 2012 | 11:14 PM
A5scott's Avatar
thanks guys... I'm not a worry type... looks like i'll be ok for a bit
until the next problem....
thanks
Old Jul 2, 2013 | 08:58 PM
collector87's Avatar
Got in my 2001 DII tonight, started it, and pressed the brake pedal down and heard and felt a clunk from below the shift stick - never heard/felt this before - seems to be doing it every time I'm in park and press the brake now - assume it has to do with the shift lock...? Advice? Will this worsen? What can I check? Do? Thanks!
Originally Posted by A5scott
ok, so my D2 is running and I'm parked, I tap the brake to put it in Reverse, and I hear a noise in two places simultaneously. in the left side by the turn signals, I hear what sounds similar to the turn signal noise... and at the same time I hear and feel a light tapping sound from under the shifter... like something is poking up from under the shifter.
only happens when it's running, in Park, but not when moving
no idiot lights are lit on the dash... but the ultra gauge is showing pending code 1668. maybe unrelated
any ideas?
thanks
scott
Old Jul 2, 2013 | 09:06 PM
Mojigglins's Avatar
It is normal!! No need to worry!! Just read the entire thread carefully!
Old Jul 3, 2013 | 08:06 AM
grandkodiak's Avatar
Even if it does fail its real easy to manually operate... it just pushes in with your finger or tip of a screw driver. Its possible that its all gummed up... take a look at it, maybe a quick wipe with an pb blaster soaked q-tip on the pin will make it nice and smooth.
Old Jul 3, 2013 | 11:08 AM
A5scott's Avatar
I keep a spare brake switch in my car just in case it fails on the road. About $45 from auto parts store and easy enough to replace.
Scott
Old Jul 3, 2013 | 04:44 PM
How can this be normal if it just started happening?
amer_qureshi
Jul 10, 2024 02:03 PM
Green Manual Disco
Sep 7, 2012 02:18 PM
rwhite2001
Mar 9, 2007 10:24 PM
04DiscoOwner
Dec 22, 2006 09:39 PM
Strider
Sep 23, 2006 03:39 PM
