Trans Fluid question
Old May 25, 2010 | 07:52 PM
aemnky606's Avatar
Default Trans Fluid question
I'm changing my trans filter and doing a flush on the system and the book calles for dextron IID. All I can find is DextronIII of Dextron 4. Is this going to be any problem. I think its not going to matter but just asking.
Thanks
Walter
Old May 25, 2010 | 08:03 PM
Dexron III will be fine.
I think the IID is the old fluid and the III is the next newest and the 4 is the newest yet, make sense?
So 3 will replace 2 and 4 will replace 3.
I am assuming you mean for a automatic transmission.
But if you want to know for 100% you could always call a dealer.
Old May 25, 2010 | 08:18 PM
lordmorpheus's Avatar
Yes. Originally it was just called Dexron, then came Dexron II, IIE,...then Dexron III. In 2006 GM came out with Dexron VI. All Dexron numbers are backwards compatible. You can use VI in applications that call for II or III, but not the other way around.
Old May 25, 2010 | 08:22 PM
lipadj46's Avatar
All dexrons are backwards compatible. Use the latest and greatest or one of the generic dexmercs like maxlife.
Old May 25, 2010 | 08:30 PM
aemnky606's Avatar
thanks guys. I was thinking that it would be ok to use.
Walter
abran
Apr 27, 2014 06:59 AM
The People Family
Aug 6, 2008 10:32 PM
texmanmoore
Feb 23, 2008 09:18 PM
bradbenz
Feb 15, 2008 04:47 PM
merleti
Freelander
Aug 28, 2007 05:24 PM
