Trans Oil Temp light!!!
Old May 18, 2007 | 08:22 PM
bamarover's Avatar
Default Trans Oil Temp light!!!
The Trans Oil TEmp light came on today and it hasn't turned off in like two hours of sitting still. where do i add the stuff?
Old May 18, 2007 | 10:01 PM
okdiscoguy's Avatar
Default RE: Trans Oil Temp light!!!
I think you have fill plugs. You have to open the level plug with the truck running. Not positive on this, though. I am sure someone else with a d2 will chime in. You don't have a dipstick....
I would suggest getting a rave CD. They are like $10 on ebay, and I got one free from rover-renovations.com . It has all of the trucks on it. Really cool info
You might also check the temp sensor wires. I know you go offroad. Something may have come loose...
Old May 19, 2007 | 12:17 PM
bamarover's Avatar
ok, it might be that. should i attempt to take it to the dealership?
Old May 19, 2007 | 01:00 PM
okdiscoguy's Avatar
is the light on when the tranny is cold?
Old May 19, 2007 | 02:53 PM
I agree, if the light is on when the tranny is cold, your mode lights aren't flashing and it is shifting, you should be fine to drive to the dealer.
Mike
Old May 20, 2007 | 09:10 PM
bamarover's Avatar
light went off. ehhhhhhhhhh
Old May 21, 2007 | 08:24 AM
Did you have to add alot of ATF, if so I would suggest you service the tranny. If you didn't add any fluid and the light just went off by itself, it may come back on again because of a pinched wire or bad switch.
Mike
oilspotLR
Oct 30, 2015 03:47 PM
rugbydoc1
Jul 24, 2013 05:18 AM
Robmcin
May 10, 2009 05:08 PM
bamarover
May 18, 2007 09:33 PM
97DISCOIDAHO
Sep 9, 2006 11:04 AM
