transfer case
Old Nov 10, 2007 | 08:30 AM
jesse682000's Avatar
4th Gear
Default transfer case
So I need to put a new transfer case in my 1995 Discovery AT. Would a transfer case from a 1996 fit? I found oneon craigslist for375 bucks. Thanks for any help.
Old Nov 10, 2007 | 09:01 AM
Default RE: transfer case
Per this site and their information, I would say no.
http://www.roverlandparts.com/index....S&Category=280
Old Nov 10, 2007 | 10:30 AM
4th Gear
Thanks Mike. I don't know if you remember, but I'm the guy that bought my disco and found out the guy before me had been driving it all around with the diff lock engaged. Anyway...I just finished with the front drive. The front diff is still good. I replaced both front cv joints. Now I am going to embark into changing out the transfer case and I should be all good after that.
Old Nov 10, 2007 | 10:36 AM
What is the t/case doing that you fell you must replace it?
Old Nov 10, 2007 | 11:20 AM
4th Gear
With the diff lock engaged only the rear wheels move, with the diff lock disengaged only the front wheels move...Before I replaced the CV joints only the front drive shaft moved.
Old Nov 10, 2007 | 11:40 AM
Sounds like she has been fried, Too bad.
Old Nov 10, 2007 | 09:04 PM
Mark G's Avatar
Have you considered rebuilding it? Have you split it to see what items are worn? Might be able to do it cheaper (or as cheap) as buying an "also ran" considering shipping. I've rebuilt a couple (not Rover) andthey werereally a cinch. Alot fewercomponentsthan tranny's. Personally, I'd split it open before committing on buying a used one, just to see.
Old Nov 11, 2007 | 10:54 AM
ajh's Avatar
ajh
That's only an option if he has the time and another vehicle.
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
