Transfer Case Fill Plug - Access Method
Hi all,
Quick question - looking to change my transfer case fluid. Tried to get under there with a breaker bar and a socket, but didn't seem to fit between the parking brake cable and the back of the tcase. Tried a wobble extension but it was too fat. I have like a 3" 1/2" extension but that doesn't help.
Do you guys just use a 1/2" extension to put the socket behind the parking brake drum? If so, how long of an extension should I pick up?
Thanks! Tried searching but couldn't find an answer to this one...
The following 2 users liked this post by zski128:
Best4x4 (08-25-2020),
Richard Gallant (08-25-2020)
I’ll offer a contrarian opinion - I tried the serpentine belt tool at one point and couldn’t use it because the serpentine tool doesn’t have a ratcheting head and the orientation of the plug was such that in order for the plug to match up with the head of the tool, the handle would interfere with the frame or exhaust.
This is how I removed my access plug. Simply moved the harness out of the way, and then popped in the ratchet (only works without the extension).
Four Engines and Counting
02-08-2018 10:02 PM
JBEGIN
04-30-2009 01:19 AM
