Transfer Case Fill Plug - Access Method
Old Aug 25, 2020 | 07:08 PM
boston4's Avatar
Default Transfer Case Fill Plug - Access Method
Hi all,
Quick question - looking to change my transfer case fluid. Tried to get under there with a breaker bar and a socket, but didn't seem to fit between the parking brake cable and the back of the tcase. Tried a wobble extension but it was too fat. I have like a 3" 1/2" extension but that doesn't help.
Do you guys just use a 1/2" extension to put the socket behind the parking brake drum? If so, how long of an extension should I pick up?
Thanks! Tried searching but couldn't find an answer to this one...
Old Aug 25, 2020 | 07:15 PM
merebel's Avatar
Yeah someone help here, as I also need to knock this out still
Old Aug 25, 2020 | 07:45 PM
mln01's Avatar
I just used my ½" torque wrench with no socket on it. I recall it being a snug fit but worked with little trouble. Good luck.
Old Aug 25, 2020 | 09:07 PM
zski128's Avatar
Serpentine belt tool with 1/2” square drive on the end.
Old Aug 25, 2020 | 09:14 PM
Richard Gallant's Avatar
@zski128 for the win a cheap 1/2 drive serpentine tool works perfectly
Old Aug 25, 2020 | 10:11 PM
boston4's Avatar
Mmmmmm got it, I haven't needed a dedicated serp belt tool. I will try just pushing the parking brake cable out of the way with my ratchet and if that fails, I'll pick up one of those.
Thanks for the responses!
Old Aug 26, 2020 | 07:04 AM
Las4444's Avatar
6th Gear
This is what I
use use
to break it loose. I just use longer 1/2" extensions. Too cheap to buy serpentine belt tool.
Old Aug 26, 2020 | 08:29 AM
zski128's Avatar
You can rent the serpentine belt tool at most auto parts stores for free.
Old Aug 26, 2020 | 09:47 AM
Brandon318's Avatar
I’ll offer a contrarian opinion - I tried the serpentine belt tool at one point and couldn’t use it because the serpentine tool doesn’t have a ratcheting head and the orientation of the plug was such that in order for the plug to match up with the head of the tool, the handle would interfere with the frame or exhaust.
Old Aug 26, 2020 | 10:11 AM
acg's Avatar
acg
This is how I removed my access plug. Simply moved the harness out of the way, and then popped in the ratchet (only works without the extension).
Four Engines and Counting
Feb 8, 2018 10:02 PM
huggi
Jun 13, 2017 12:59 PM
bostongrun
Apr 15, 2012 09:55 AM
Phototone
Apr 7, 2008 03:59 PM
