Transfer Case Filler Plug Location
Old Apr 15, 2012 | 08:57 AM
bostongrun's Avatar
Default Transfer Case Filler Plug Location
I have seen a number of posts concerning the difficulty of changing the transfer case fluid on Discos. Most of these regading frustrations locating and removing the filler plug. Yes, there is in fact a filler plug it's located on the rear of the case just behind a cable wraped in foil. The plug does not have a hex rather a 1/2 drive drive indentation. It's very hard to access owing to it's proximity to a large drum on the back of the transfer case. I tried for an hour to get it out and gave up. I finally came up with a procedure that took less than five minutes!! I used one of those adapters you put an a 1/2 inch socket that has a hex on it. These are used for tight spaces. Put the hex adaptor right in the plug, you might have to bang on it a little if it's rusty. Once I got it stuck in there I put an 11/16 open ended wrench on the hex. Then I wacked the wrench with a hammer and it came loose after two whacks!!!
Old Apr 15, 2012 | 09:09 AM
Great. And some owners back up on ramps, to give a little more working space (for chubby DIY), and allows you put a little more fluid in. I use a 1/2 inch ratchet and a short extension, have also used a "universal" joint style extension. I like your idea.
Old Apr 15, 2012 | 09:55 AM
That "wire bundle" is the parking brake cable.
That drum is the parking brake.
The fill/check plug takes a 1/2" drive breaker bar or ratchet.
Same as the plugs on the differentials.
Robmcin
Jun 24, 2009 02:22 AM
DiscoNoisebox
May 2, 2009 02:46 PM
fp360spidr
Jul 22, 2007 03:05 PM
jacksyachts
May 2, 2007 11:49 AM
imag
May 12, 2006 07:59 PM
