Transfer case gasket
Hi guys,
I searched the forum but cant find a definite answer. I need to reseal my transfer case bottom cover as my seep has turned into a drip. What gasket/sealant should I use? I have read both RTV and "Right Stuff" do the job but I am curious to know if anyone has any experience with which one is better. Thanks in advance for the help.
RTV seems to work in the D1's, see D1 Transfer Case Fluid Change with Pictures - Land Rover Forums - Land Rover Enthusiast Forum for the write up that is in the tech sticky along with photos. I think I had to remove a small heat shield to get at one of the bolts. You'll want to dab the part of the threads of the bolts, they are threaded all the way through the lip of the case.
archaeology_student
08-02-2014 09:43 AM
