Transfer case gasket
Old Aug 1, 2011 | 12:27 AM
willrok13's Avatar
Default Transfer case gasket
Hi guys,
I searched the forum but cant find a definite answer. I need to reseal my transfer case bottom cover as my seep has turned into a drip. What gasket/sealant should I use? I have read both RTV and "Right Stuff" do the job but I am curious to know if anyone has any experience with which one is better. Thanks in advance for the help.
Old Aug 1, 2011 | 03:58 AM
RTV seems to work in the D1's, see D1 Transfer Case Fluid Change with Pictures - Land Rover Forums - Land Rover Enthusiast Forum for the write up that is in the tech sticky along with photos. I think I had to remove a small heat shield to get at one of the bolts. You'll want to dab the part of the threads of the bolts, they are threaded all the way through the lip of the case.
Old Aug 1, 2011 | 05:21 AM
cdm's Avatar
cdm
i used rtv grey. you have to remove the crossmember though, and i can guarantee you those bolts will strip/break. thats the worst part of the job.
Old Aug 1, 2011 | 07:28 AM
antichrist's Avatar
I just removed two bottom covers from '95's yesterday, neither had any bolts strip or break.
Old Aug 1, 2011 | 10:13 AM
willrok13's Avatar
You were correct CDM, the bolts were rusted and spun off when I tired to back them out. Thanks for the heads up.
Old Aug 2, 2011 | 03:00 AM
cdm's Avatar
cdm
you have a D1 mate. you dont have that under there
archaeology_student
Aug 2, 2014 09:43 AM
aftermath431
Oct 17, 2013 07:53 PM
JRover83
Sep 29, 2012 07:34 PM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
