Transfer case leaking
Old Jul 8, 2019 | 05:13 PM
EAustin494's Avatar
Default Transfer case leaking
Hi all,
i went on vacation and left my 03 D2 sitting in the garage and came home two weeks later to various puddles. One of them seems to be coming from the bottom plate of the T case. Is this a common leak point? Do you just get the kit from AB and swap out the gasket or am I going to run into some nightmare?
Old Jul 8, 2019 | 05:14 PM
Brandon318's Avatar
Curious as well. Same leak here.
Old Jul 8, 2019 | 07:05 PM
Ben Matheson's Avatar
Pretty much any leak will end up there as it's the lowest point on the transfer case. Clean everything and look to see where it's coming from
Old Jul 8, 2019 | 07:06 PM
If it's just the cover leaking there is a thread about removing and resealing. Not hard
Old Jul 8, 2019 | 07:16 PM
Discorama's Avatar
Check the breather tubing. If it is clogged or melted, system will get under pressure and leak. It is a very easy test, just try to blow in some air at the U-end in the engine compartment with your mouth (attach a hose as extension, e.g. 1/4" fuel line fits).
Old Jul 10, 2019 | 05:47 PM
Fast951's Avatar
I made a gasket for the cover - this link may be helpful for you.
https://landroverforums.com/forum/di...e-92245/page1/
bhowell450@gmail.com
Jul 30, 2017 01:44 AM
Bob Loblaw
May 14, 2013 09:46 AM
jfall
Mar 21, 2013 02:30 PM
Jared9220
Oct 28, 2012 10:50 AM
starcraft1
Jul 27, 2012 07:32 PM
