Transfer Case Neutral Sensor 2004 Disco 2
Old Mar 25, 2021 | 08:59 PM
Ninetoe's Avatar
7th Gear
Default Transfer Case Neutral Sensor 2004 Disco 2
I need to order this sensor but can't find a part number or this part on any website. It is described like this by Land Rover:Neutral sensor
A neutral sensor is fitted for North America and Japan. The sensor is connected to the BCU and is normally in the open position. The sensor provides an earth path for the BCU which then interprets the signal and activates an audible warning generated by the IDM if neutral is selected on the transfer box when the ignition is on.
Also just order the high/low sensor, part number was IGM100000. Picture looked identical but a comment on the forum said the 2004 sensor was different??
A high/low detect switch is fitted in the front output housing and connects to earth when low is selected.The switch is connected to the engine ECM, the SLABS ECU and the BCU. The purpose of the switch is to enable selection of the hill descent feature and to modify the engine fuelling and automatic gearbox gearshift maps stored within the respective ECM’s and ECU’s.
Thanks for help
Old Mar 26, 2021 | 06:52 AM
redwhitekat's Avatar
IGM100000 try google search
Old Mar 26, 2021 | 06:53 AM
Transfer box switch low range part number IGM100000 for all models of the Land Rover Defender year 1987 onwards and Discovery 2.
5101520253035404550 per page
Sort By: Product Price Default Sales
Brand: ORIGINAL EQUIPMENT Part Number: IGM100000.TR Price: CA$56.01 excl VAT
CA$56.01 incl VAT
Quality: Original Equipment in Plain Box Note: LOWEST PRICE FOR 2 + Availability: IN STOCKQuantity 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
Add to CartAdd to Wish List
Brand: ORIGINAL EQUIPMENT Part Number: IGM100000.C8 Price: CA$59.02 excl VAT
CA$59.02 incl VAT
Quality: Original Equipment in Plain Box Note: 2 YEAR WARRANTY Availability: IN STOCKQuantity 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
Brand: LAND ROVER Part Number: IGM100000.L8 Price: CA$91.84 excl VAT
CA$91.84 incl VAT
Quality: Original Part from Land Rover UK Note: 1 YEAR WARRANTY Availability: SUBJECT TO LR STOCK + 1 DA
Old Mar 26, 2021 | 09:34 AM
Ninetoe's Avatar
7th Gear
Yes I found high/low switch but still need the neutral position sensor. Can’t seem to find it anywhere or even determine part number.
Old Mar 26, 2021 | 04:22 PM
Richard Gallant's Avatar
@Ninetoe Rimmer or Bearmach is where I got mine
Old Mar 26, 2021 | 05:42 PM
Ninetoe's Avatar
7th Gear
I found number on Russian website after extensive searching, Part number for neutral sensor on transfer case is AMR6666.
journeyman
Nov 20, 2023 04:13 PM
bcmouser
Jun 2, 2014 10:33 AM
thehun
Oct 5, 2011 11:21 PM
DiscoveryHouston
Defender
Sep 26, 2009 10:02 AM
wielgoshoff
Engine & Internal
Mar 18, 2008 11:37 AM
