Transfer case rear output shaft bearing
Old Apr 15, 2019 | 02:04 PM
Colorado David's Avatar
Default Transfer case rear output shaft bearing
I need to replace my rear output shaft bearing. Ive downloaded RAVE, but it has never worked on my Mac. I've been using the D2 Workshop Manual instead. It doesn't give me the procedure for replacing this bearing. Can anyone give me a quick tutorial? Thank you.
Old Apr 15, 2019 | 06:52 PM
mollusc's Avatar
i think the "d2 workshop manual" is just a sub-pdf of the rave that comes up when you pick the d2 part of the rave menu, so you're probably not missing anything document-wise.
Old Apr 15, 2019 | 06:53 PM
shanechevelle's Avatar
What kind of phone do you have?
Old Apr 15, 2019 | 08:43 PM
iPhone 7+. I found a YouTube video that helped. They had the transfer case out and on a bench. I’m hoping to replace the bearing without having to remover the t-case. I changed the output flange and oil seal this afternoon and was able to inspect the bearing.
Old Apr 15, 2019 | 08:48 PM
Jeff Blake's Avatar
It's definitely in there.. look in the overhaul section under differential. You have to take off the whole rear housing, and I'm pretty sure, can't remember the process exactly, you might need to take out the front output housing, center diff, high-low fork, etc as well. I can't remember
Old Apr 15, 2019 | 09:00 PM
The YouTube video removes the output flange and oil seal, then removed the circlip that retains the shaft and then used a slide hammer to pull the shaft. Removed the old bearing and pressed on the new bearing and reassembled. It looked like a couple of hours work under the car. I’ve been as far as the oil seal today. I hate working under the car, but it doesn’t look that much harder to replace the bearing after you get as far as the oil seal.
Old Apr 16, 2019 | 02:15 AM
JUKE179r's Avatar
@Colorado David ... Do you have a link to the YouTube video so it can help others?
Old Apr 16, 2019 | 04:56 AM
Old Apr 16, 2019 | 06:15 AM
Put the rave on your phone and download an app that will open it. I have android which is basically a Mini computer and that's what I do.
KingKoopa
Jun 11, 2017 06:50 AM
ralphobell
Nov 3, 2014 03:08 PM
FlyingZebra34
Mar 7, 2014 12:39 AM
Aeronaut
Oct 19, 2013 12:33 PM
Mountainman
Defender
Apr 16, 2007 10:19 AM
