Transfer case rebuild?
Old May 3, 2023 | 12:00 PM
Mullins.cody's Avatar
Default Transfer case rebuild?
I was looking at trying to get a tcase with center diff lock. Found one with high mileage (180,000) for cheap. Would it be worth rebuilding it with a rebuild kit or should you avoid high mileage tcases in general?
Old May 3, 2023 | 02:13 PM
Harvlr's Avatar
I haven’t done a t-case yet but I would expect if you rebuilt it, it would be as good as new.
Old May 3, 2023 | 05:45 PM
Extinct's Avatar
Probably does not need rebuild. Replace o-ring on center shaft and seal with permatex moto seal or high torque silicone and send it.
Old May 3, 2023 | 07:50 PM
Extinct's Avatar
Oh, you could just swap the nose off the locking tcase in to your 03 tcase. A little easier than changing the entire tcase. But of course you can't change the center shaft seal if you do it that way.
BoulderCharles
Feb 12, 2021 08:25 PM
Bal D Correa
Feb 21, 2020 05:20 PM
Braxton
Sep 7, 2013 08:41 PM
ShortTom
Aug 16, 2010 07:41 PM
Loose_Screws
Jul 22, 2005 12:13 AM
