Transmission
Old Apr 12, 2019 | 06:30 PM
eskiltell's Avatar
Default Transmission
Hello all,
Just a quick question, will an 04 trans fit my 01? Google didnt come up with an answer.
Old Apr 13, 2019 | 03:19 AM
DavidOHendo's Avatar
Banned
It's a better tranny than the 01 .. higher tolerances .. better uphill .. better pulling .. don't know if it matches though .. let me know when you find out
Old Apr 13, 2019 | 01:43 PM
Dweeb Discovery's Avatar
Default Dweeb
Yes! And here we have it! The first post in the Dweeb Discovery Hall of F(Sh)ame! The first of several for this guy, I expect.
On what basis do you say this? The HP24 transmission from the '03-'04 DIIs is virtually identical to the HP22 used in the "99-'02 trucks. Upgraded to mate with the higher horsepower of the 4.6, but "higher tolerances .. better uphill .. better pulling .." Where do you get this stuff? And then you can't even answer the OP's question! Get a life!
Old Apr 13, 2019 | 04:33 PM
Ben Matheson's Avatar
They are not the same length
Old Apr 13, 2019 | 04:57 PM
Extinct's Avatar
Will Tillerey sells the HP24 for the same price as the HP22, and the forward clutch is much better. Get the 24 with the driveshafts to fit.
Old Apr 13, 2019 | 05:21 PM
eskiltell's Avatar
So basically an 04 driveshaft?
Old Apr 13, 2019 | 06:25 PM
Best4x4's Avatar
I slapped an HP24 into an 01 with very little fuss. I re-used the shafts that were on the 01 (now if the owner had changed them to an 03-04 setup = unsure). The transmission/TC mounts = where I had to tweak it a little. I did install a newer 03-04 Transmission ECU as well.
I've owned a lot of HP22 D2's and I personally have yet to have any sort of failure. The HP24 is just an updated HP22 that was improved in a few spots for the 4.6L engine. OEM Front Drive shafts don't care if it's an HP22 or HP24 as they'll die in the exact same fashion lol.
abran
Apr 27, 2014 06:59 AM
b63215b
Aug 8, 2012 09:20 PM
LRDalltheway77
Aug 17, 2009 06:31 AM
rwp389
Jun 21, 2007 04:11 PM
