Transmission blinking M and S same time
Old Jul 25, 2015 | 11:42 AM
fikus555's Avatar
Thx all for replies!!!i'm waiting on a brake booster to arrive(it starts leaking),as soon as i installed it, will start working on M S problem and will update what was wrong!
Thx.
Old Jul 26, 2015 | 08:13 AM
NickAdams's Avatar
Your symptom may have a different cause than my experience, but when my crank position sensor failed and (almost) left me stranded, I waited for it to cool down, got the truck started and drove home. The M & S lights flashed the whole way (15 miles) but I made it.
Old Jul 26, 2015 | 02:24 PM
jfall's Avatar
Put in a new XYZ.
I would only go in the water / mud if you absolutely have to. As there are always repair penalties.
Make sure the battery and alternator are new too as low voltage could cause the flashing too. The solenoids in the transmission need to PULL IN to affix the clutches in the planetary gear train and if they don't pull in then you get a fault code.
The more voltage the more magnetic force the solenoids have to pull in the clutches to grip.
At the worst - you have transmission damage.
But probably just the XYZ
Old Jul 27, 2015 | 06:28 AM
drowssap's Avatar
check your battery and alt it has to put out 13.5 or better otherwise you will get flashing m&S
Old Nov 13, 2015 | 04:11 PM
fikus555's Avatar
fixed xyz switch ,the contacts wasn't touching the contact lines,so just bent them out , put it back,now all working perfect.used rivets.
Attached Thumbnails Transmission blinking M and S same time-img_1769.jpg   Transmission blinking M and S same time-img_1775.jpg
Old Nov 14, 2015 | 06:48 AM
drowssap's Avatar
Well done.
ajtrujillo15
Mar 31, 2015 07:55 AM
UProver
Jun 25, 2011 04:53 PM
MBirtch
Jul 19, 2007 11:02 PM
