Transmission Fluid
Old Aug 17, 2013 | 10:59 AM
mwelton's Avatar
Default Transmission Fluid
After studpidly checking the transmission fluid while the truck was cold earlier this week and spilling about a quart of transmission fluid I planned on refilling the spilled fluid this morning. After letting the truck idle to warm up and then driving a couple of miles i pulled back in and checked with the truck running I still had fluid running out of the fill hole. It would seem that the last time the fluid was changed too much was put in. Should I be worried about the lost fluid?
Old Aug 17, 2013 | 12:28 PM
You check and or fill it with the engine running.
Old Aug 17, 2013 | 12:41 PM
mwelton's Avatar
I know, which is why I asked the question...
Old Aug 17, 2013 | 01:08 PM
Is your truck sitting level, what color is your ATF, crystal red, redish or brownish?
Old Aug 17, 2013 | 01:12 PM
mwelton's Avatar
Yes truck is on level ground. ATF was still nice and red.
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
ferrelltodd
Aug 9, 2005 10:11 PM
