Transmission Play and Front Drive Shaft
Old May 1, 2008 | 06:00 PM
Default RE: Transmission Play and Front Drive Shaft
ORIGINAL: NiteTrain
have you noticed any MPG gains with the front shaft out?
You will utlimatly destroy your rear diff if you run it this way to long. Any MPG gains will be used up in repairs.
Old May 1, 2008 | 08:19 PM
roverguy7's Avatar
you wont ruin the rear diff at all. you will however destroy the entire basis of havin a landrover, 2wheel drive, dont do it. you might get 1mpg gain out of it, but is that really worth changing your disco into a explorer?
[/align]
Old May 2, 2008 | 01:20 PM
Now I was told that running on the rear diff only would put extra strain on it and it would grenade at some point.
Old May 4, 2008 | 02:33 PM
roverguy7's Avatar
itsa pretty beefy diff. it can easily handle all 230 ft. lbs that engine can put out, physicly, it will be fine.
Old May 4, 2008 | 05:32 PM
Except for the 2 very weak spider gears that will fail for any excuse.
xmarksit
Nov 26, 2013 08:37 AM
cookci
Nov 3, 2013 08:49 AM
Aeronaut
Oct 19, 2013 12:33 PM
RoverPete
May 7, 2013 07:42 AM
yoshibond
May 6, 2012 12:18 AM
