Transmission question
Old Apr 13, 2021 | 06:08 PM
jdbayer's Avatar
Default Transmission question
I went to check the fluid in the transmission today because I’m thinking about changing it. I did research online to see the proper procedure and what to expect. I crawl under there, twist off the fill plug and fluid shot out of there. It had the same flow as when I pull the oil drain plug. Does this mean the transmission was over filled?
Old Apr 13, 2021 | 06:12 PM
cvhyatt's Avatar
Was it hot or cold? Mine shot out too when I opened it while it was hot.
Richard Gallant's Avatar
If your engine is not running that will happen, the engine must be running.
Old Apr 13, 2021 | 06:15 PM
jdbayer's Avatar
Cvhyat, it was slightly warm. It had been sitting for a couple hours.
Richard, that is good to know. I read a couple places that it needed to be in neutral. Is this true, or Amit be in park?
Old Apr 13, 2021 | 06:23 PM
Discorama's Avatar
Just follow the instructions here:
Richard Gallant
Jan 26, 2019 06:00 PM
djkronik57
Nov 3, 2016 11:19 AM
chicane
Apr 11, 2014 08:04 AM
FLDiscoII
Jun 19, 2012 10:47 AM
Newbie
Nov 23, 2007 11:08 AM
