transmission question
Old Dec 9, 2008 | 12:09 AM
theworks001's Avatar
Default transmission question
I've been looking for the transmission filter does anybody know where to get it??
Also how hard is this to do??
My cooler pipe is leaking and want to replace them all, so might as well do the the filter because I will have to drain the tranny right?
Please help
thanks
Old Dec 9, 2008 | 08:44 AM
discoxd's Avatar
Default RE: transmission question
oreilley auto parts has been a very productive place for me to find parts... i think the trans filter is like 15 bucks there... they will have to order it i am pretty sure but it should only take like a day or two to come in
Old Dec 9, 2008 | 08:51 AM
Atlantic British and Rover Connection are good places to find the filters.
It is a fairly hard job to change the filter, the cross member needs to be removed and the "Y" pipe will need to be loosened and moved.
Old Dec 9, 2008 | 04:33 PM
Yes you will need to drain the trans fluid, there is a drain plug for that.
And like Mike said, it is a real PIA to change the trans filter on a DI.
I bought my trans filter from www.atlanticbritish.com
Old Dec 9, 2008 | 04:38 PM
Street Wolf's Avatar
Go to O'Reillys. They should have it.
Old Dec 9, 2008 | 05:07 PM
Tinkertrek's Avatar
4wd High
I just bought a transmission filter for a D1 at NAPA about two weeks ago it was in stock.
I paid around $45. for it came with the little O ring, pan gasket & screen (filter).
I've had good luck with NAPA here in the Denver area getting parts for D1's.
Old Dec 10, 2008 | 11:15 AM
Consider adding a bottle of Lucas to your tranny fluid and also switch over to Vavoline's high mileage Dextron for better results.
hubris
Dec 14, 2007 09:31 PM
open range
Mar 21, 2007 02:00 AM
Benhamtroll
Feb 9, 2007 11:17 PM
stripperluvva s wife
Mar 24, 2006 11:49 AM
JKK
Oct 13, 2005 10:49 PM
