Transmission rebuild
Old May 1, 2011 | 06:48 PM
skunkridge's Avatar
6th Gear
Default Transmission rebuild
I have a 2000 Discovery that I havent driven in over 3 years because the transmission "blew" in it. I only had reverse. I have finally found and bought a ZF rebuild kit for the transmission. With it came a atsg manual that kinda sucks, its been reproduced way too many times and you cant see any of the photos. The text and tech drawings are still good. I am looking for a good manual for rebuilding the transmission.
Another concern I have is that one of the codes was for "torque converter slipping". Does this mean the torque converter has failed as well and needs to be replaced?
ANY tips or info reguarding this project is appreciated.
Old May 1, 2011 | 09:00 PM
Have you visually inspected the transmission housing for damage?
Old May 1, 2011 | 09:20 PM
mwindth's Avatar
Wink Land Rover Service Manual (RAVE; do search for transmission)
Land Rover Service Manual (RAVE; do search for transmission):land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
LR Owner's Manual (in case you do not have original):Land Rover Owner Information (prs01736)
Ask questions as you go. Good luck!
Old May 2, 2011 | 06:14 PM
coors's Avatar
How do you know the TC is NOT the problem? I had an Audi, which used a ZF Trans, people we're always complaining and commenting on the forums that the ZF's TC were notorious for failures. Not sure how close in comparison our trans's are to the one's used in the C5 Audi's? But...
I would start with replacing the TC (given the code you listed above). Get a cheap used one (from a salvage yard), re-install, and see if the truck has forward gears. A lot cheaper and a lot less work. If the truck has been sitting for 3years, theres obviously no rush to get it back on the road. Think about it, if it's only the TC you are saving yourself a ton of time and aggravation. Just my two cents...
Old May 2, 2011 | 06:33 PM
skunkridge's Avatar
6th Gear
spike, the housing looks good, i also had it at a garage here that was recommended by some of the few lr owners around. that is why i've concluded that it is the trans. also.
Mwindth thanks for the link, thats wicked. i actually bought the disk version of this years ago and cannot find it.
coors, i just might, after removal, swap in a different tc and reinstall on your two cents. thanks.
i will update
Old May 2, 2011 | 08:02 PM
coors's Avatar
i will update
keep us posted.
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
discoxd
Nov 25, 2008 05:28 PM
