Transmission rebuild kit
Old Aug 25, 2013 | 02:09 PM
eitydeuce's Avatar
Default Transmission rebuild kit
Hey guys anyone know where to get a trans rebuild kit for a 00 disco? Looked at AB but didn't see any. My trans is starting to whine a lot more now and kinda want to be prepared if it does go out. I just recently changed the fluid and filter so I'm not sure how long that will last. I also put some Lucas trans conditioner in there to help out.
Old Aug 25, 2013 | 02:15 PM
jafir's Avatar
Rockauto sells the rebuild kits. You'd probably have to go through a ZF dealer if you find you need any hard parts. Or get used parts from a transmission with a big hole in it.
Old Aug 25, 2013 | 09:14 PM
SWAINROVER's Avatar
Default parts
look up ashcroft uk they will have parts . i ordered last monday to rebuild my t case parts where at my door step on thurs thats right 3days
Old Aug 26, 2013 | 06:35 AM
drowssap's Avatar
you can find ZF rebuilding kits on line, but this is not a two speed power glide tranny. Unless you have a lot of practice rebuilding electronic trans this is not the one to learn on.
Old Aug 26, 2013 | 07:08 AM
This stuff will reduce noise... widely available. Dr. Tranny Instant Shudder Fixx
Old Aug 26, 2013 | 08:50 AM
So, when was the last time you serviced your tranny, diffs and t/case?
Might seriously want to do this and pay attention to all the fluid conditions especially the color and smell of the ATF.
Old Aug 26, 2013 | 10:26 AM
To gauge difficulty of rebuild job, consider PM to Higgs Boson; if he does not have his hands in three of them on his bench he can tell you what to expect. As others have stated, not the ideal first time DIY project.
Old Aug 28, 2013 | 07:48 AM
drowssap's Avatar
a likely problem would be a cracked or fracture high clutch plate, someone else had the same problem. it also happens to jags causing them to be real late shifting into OD.
Old Aug 28, 2013 | 09:27 AM
caymandrew's Avatar
Land Rover Discovery ZF4HP22 Transmission Rebuild KIT | eBay
Old Aug 28, 2013 | 11:20 AM
drowssap's Avatar
slightly less than a used tranny
TripleThreat
Jun 19, 2015 06:43 AM
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
