Transmission slip
Old 01-26-2011, 01:58 PM
khuds308's Avatar
Question Transmission slip
2000 disco II auto
The truck is slipping (mild) in 3rd and 4th gear. when you go through the gears manually it doesn't slip at all. I replaced the transmission filter and fluid and the problem is still there. the vehicle doesn't hesitate going into gear when you start it up it's only while driving. I thought it might be a pump seal, but with no hesitation upon start up i have ruled that out. could it be a solenoid?
I took it to the shop and it's putting out two codes:
active code is p0734- gear 4 incorrect ratio
pending code is p0733- gear 3 incorrect ratio
any help would be greatly appreciated.
Old 01-26-2011, 02:50 PM
khuds308's Avatar
ah the search function. sorry about the post. cleaning the MAF out now, and waiting for a new air filter.
Old 01-27-2011, 11:10 AM
If you didn't clean the MAF when it was stone cold, then reinstall after totally dried, it will most likely fail and need to be replaced.
I am thinking that since you don't have any of the other codes that would show up with a failing MAF, like running too rich or lean or one of the 100-1004 codes, that you have have another issue, especially because when a 733 or 734 code shows up together it is more likely a tranny issue.
Let us know what you find?
Old 01-27-2011, 06:59 PM
lordmorpheus's Avatar
Are you saying the D2 MAFs can be cleaned this way? As long as I can remember, all I have ever heard was D2 MAFs CANNOT be cleaned. I have never had a problem with mine, but I couldn't see the harm in cleaning one with electrical cleaner, and would only think of doing it cold.
tee51397
04-02-2008 08:32 PM
hasallhisteeth
02-06-2008 06:55 PM
beyondyonder
07-02-2007 10:17 AM
mowthat
03-18-2007 05:44 AM
dickensheets
10-06-2006 02:53 AM
Quick Reply: Transmission slip
